captive portal
  • 1.  captive portal
    Posted Sep 24, 2012 12:50 PM
    Captive portal not authenticating with AD (NPS configured with all policies). All other SSIDS are authenticating in AD except captive portal. PAP is selected.aaa profile configured with .1x server group (RADIUS + Local Database). Any more config required ?. Local database is working.
  • 2.  RE: captive portal
    Posted Sep 24, 2012 12:51 PM
    mgeorge,
    Can you look into the event viewer on the RADIUS server to check the reason why the authentication is failing?
  • 3.  RE: captive portal
    Posted Sep 24, 2012 12:57 PM
    It seems the auth request not reaching RADIUS.
  • 4.  RE: captive portal
    Posted Sep 24, 2012 12:58 PM
    nothing showing in RADIUS for that user.
  • 5.  RE: captive portal
    Posted Sep 24, 2012 01:08 PM
    Can you check if the RADIUS requests are not dropped on the controller for the user role?
  • 6.  RE: captive portal
    Posted Sep 24, 2012 01:09 PM
    Could you help me with the instruction to find this.
  • 7.  RE: captive portal
    Posted Sep 24, 2012 01:32 PM
    you mentioned firewall hits ?
  • 8.  RE: captive portal
    Posted Sep 25, 2012 05:54 AM
    @mgeorge wrote:
    do you mean that in the server group you defined both Radius and Local ? which one is positioned first ?
  • 9.  RE: captive portal
    Posted Sep 26, 2012 12:31 PM
    Also make sure that you have "fail through" enabled on that server group.
