last person joined: 8 hours ago
Captive portal...
  • 1.  Captive portal...
    Posted Oct 21, 2014 12:09 AM
    I’m going to use Aruba instant APs in existing Aruba controller base environment. I already have an open SSID for guest users authenticated via internal controller data base. I wanted to create the same SSID for guest users in my Instant network which is deployed in expanded buildings in the same premises.
    In this case can I use the existing internal user database in the controller to authenticate users via  Aruba instant network?
  • 2.  RE: Captive portal...
    Posted Oct 30, 2014 12:33 PM
    the only way i know to get this work is:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Tutorial-Guest-only-solution-using-IAP-GRE-tunnel-with/td-p/147880
    I think you must use controllers wired captive portal...
    If you found my post helpful, please give kudos
