Captive portal and CPPM certificates
  • 1.  Captive portal and CPPM certificates
    Posted Sep 18, 2019 04:08 PM
    Quick question about how the certificates should be generated for use in a multi-controller + cppm cluster with external captive portal environment using a controller-initiated workflow. I want to make sure I understand exactly what needs to be used for the CNs, SANs and captive portal URL.
    This would be for an aruba 8 environment with multiple controllers and a cppm cluster with publisher/subscriber.
    VIP #1: Primary subscriber, secondary publisher
    VIP #2: Primary publisher, secondary subscriber (for standby publisher)
    Certificate 1 (For Controllers)(Publicly signed):
    CN=wifi-login.domain.xyz
    SAN=wifi-login.domain.xyz
    This certificate would be uploaded to each controller to be used as the captive portal profile. This CN would NOT be registered in internal DNS. This needs to be publicy signed as it will be used for the URL redirection. The CN would be used as the NAS Vendor Settings Address/Hostname in the guest registration.
    Certificate 2 (For CPPM cluster)(Publicly signed):
    CN=wifi.domain.xyz
    SAN=wifi.domain.xyz
    SAN=cppm-pub.domain.xyz
    SAN=cppm-sub.domain.xyz
    SAN=cppm-vip-sub.domain.xyz
    SAN=cppm-vip-pub.domain.xyz
    This certificate would be uploaded in CPPM for RADIUS and HTTPS. The CN would be registered in DNS. This CN would resolve to VIP #1 in DNS.
    Controller L3 Captive Portal settings:
    URL: wifi.domain.xyz/guest/guest.php
    Is this the correct way of doing it? I got some additional clarification today on what to do, but I want to be sure. Thanks!
  • 2.  RE: Captive portal and CPPM certificates
    Posted Sep 18, 2019 04:50 PM
    Yes, correct
  • 3.  RE: Captive portal and CPPM certificates
    Posted Sep 18, 2019 05:36 PM
    Thank you so much for confirming this Tim. Much appreciated.
  • 4.  RE: Captive portal and CPPM certificates
    Posted Sep 24, 2019 11:33 AM
    Running into issues with Android devices specifically showing a certificate error on the redirect. I am using Entrust G2 root signed, L1K intermediate for my captive portal certificate. fqdn is resolving correctly.
    TAC says that Android has issues with Entrust G2. Is there any truth to that? What would be the best way to start troubleshooting this issue?
    I am not getting a cert error when going to the captive portal. It is only after the login and the redirect where I am getting that.
