Hi all, have a need to configure guest access via CP and then dest-nat to a transparent proxy, confused in which order to put the policies.
Tested proxy with a dest-nat rule and works fine but need CP first to authenticate.
The Initial role on your AAA service should be the guest-logon role
And then in the Captive Portal Auth Profile you define the Guest Proxy Role
HI,
CP policy should be mapped to logon role at initial role ( AAA profile ) and you need to add a policy to NAT the traffic to Proxy in the role mapped as the guest-user role through CP profile.
Please feel free for any further clarity on this.
