Captive portal and L3 VLAN
  • 1.  Captive portal and L3 VLAN
    Posted Mar 30, 2015 06:04 AM
    We're trying to integrate our MDM solution with our existing ClearPass-authenticated wireless environment.  The idea is that when any device connects to our SSID, if it is not MDM-enabled (as identified by ClearPass), it is given a user role which forces redirection to a captive portal where it can be enrolled with the MDM solution.
    The complication is that our wireless VLANs are not configured locally on the controller, but on the switches.  I understand that the (captive portal) VLAN where devices can enroll, should be configured locally on the controller.  However, for devices that are enrolled, we wish them to go straight to a VLAN that is not configured on the controller.  Is this possible?
  • 2.  RE: Captive portal and L3 VLAN
    Posted Mar 30, 2015 07:00 AM
    If you're using bridge mode, captive portal is not possible.
    Tim
  • 3.  RE: Captive portal and L3 VLAN
    Posted Mar 30, 2015 07:46 AM
    The VAP is configured in split tunnel mode already.  My question is whether I can achieve this captive portal user role for non-MDM-enrolled devices without having the VLANs configured on the controllers?  The reason I ask is that each of our remote locations use the same VLAN ID, but have different subnets as defined on the local switches.
    I should point at that I'm not using the captive portal for authentication, but for redirection to MDM enrollment page.
  • 4.  RE: Captive portal and L3 VLAN
    Posted Mar 30, 2015 07:49 AM
    Yes. You'd use names VLANs and return the VLAN name.
    Tim
