Captive portal auth - return users seamless login
  • 1.  Captive portal auth - return users seamless login
    Posted Nov 09, 2015 08:46 PM
    Guys if I am using captive portal auth on e.g. a WLC (7220) can I log mac addresses to allow return users to log in seamlessly - if so how is this configured ? Do I need another component / module / license ?
    I would be looking to put a timeout of say a week on this...  Are there documented limits on e.g. the MAC table assuming this is available ?
    Basically I am building a BOM against requirements ... and this is one stated REQ..
  • 2.  RE: Captive portal auth - return users seamless login
    Posted Nov 09, 2015 08:48 PM
    You would use the ClearPass platform for this. It's a feature called MAC-caching.
    Tim
  • 3.  RE: Captive portal auth - return users seamless login
    Posted Nov 09, 2015 10:08 PM
    A little bit of Kudos there Tim - thanks for your timely response ..   I will look to put up Clear Pass for NAC - Q. (Anyone) How does it interact with my WLC ...  i.e. how are client requests that hit the WLC handled - do I host the web portal on the WLC which then offloads profiling to CP ... Or does CP host the web portal and does all auth / profiling from there ? Have looked at the user / config guides ... I really need architecture solution diocuments ...
  • 4.  RE: Captive portal auth - return users seamless login
    Posted Nov 09, 2015 10:29 PM
    ClearPass hosts the web portal and handles the policy decisions. The WLC simply redirects web traffic to ClearPass when unauthenticated.
    Tim
