Captive portal authentication is not working..
  • 1.  Captive portal authentication is not working..
    Posted Jul 17, 2013 04:52 AM
    Dear Concerned,
    i want to configure the Captive Portal authen for guest users. I have made the captive portal L3 profile for guest user. In this profile what roles i have to select ?? I have select the Default Role "Guest" and Default guest role "Guest". Is it right ?
    Now In AAA profile i click on captive portal profile , what inital role i have to select ?
    Please guide me... i am a new on ARUBA equipment. using Contoller 620 and AP 105
  • 2.  RE: Captive portal authentication is not working..
    Posted Jul 17, 2013 05:40 AM
    in your AAA profile choose, inital role: guest logon
    (here is an example)
    and dont forget to choose the catpive protal u created:
    and press change/apply
    also in your l3 profile (your captive portal profile u created or u using) choose guest as the role your guests getting after they passing the captive.
  • 3.  RE: Captive portal authentication is not working..
    Posted Jul 17, 2013 06:06 AM
    Is it possible that you can take the remote session of my PC .. u may access my controller..
  • 4.  RE: Captive portal authentication is not working..
    Posted Jul 17, 2013 06:09 AM
    A. please delete ur last post (with  the teamviewer details)
    B. send me this info on private
    C. add me to your skype - asa_2plus
