We are preparing an event for several users with captive portal guest authentication.
We need to remove the message on IE sayind that the certificate is not valid.
Could it be done ?
Regards
Attachment(s)
Hi Tim,
Since this is an event of one day for press guys, the best solution and quicker is to give up https correct?
How can it be done?
beconnect,
In the Captive Portal Authentication Profile, change the protocol to http: http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Optional_Captive_Portal_.htm#captive_portal_2658586545_1042006
