last person joined: 11 hours ago
Captive Portal controller just SHA 2
  • 1.  Captive Portal controller just SHA 2
    Posted Jan 27, 2017 08:18 AM
    Hi.
    I have configured my captive portal on controller Aruba 3400 firmware 6.3.1.16, will validate user by freeradius server.
    My client wants use only SHA 2, is it possible? Could be:
    Configuration--> Management--> Certificates--> CSR--> Key length = 256 ?
    Today Key Length =1024.
    It is correct? Or not have way to do this?
    Thks
    Paulo Mauricio
  • 2.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 04:28 AM
    SHA2 can use 4 kinds of hash functions: SHA224, SHA256, SHA384 and SHA512.
    Pick any of those for an SHA2 cert.
  • 3.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 07:32 AM
    Thanks James for your response.
    Today my users go to securelogin.arubanetworks.com page and the certificate GeoTrust DV SSL CA SHA1.
    For SHA2 I have to go in configuration-->certificates-->upload a certificate?
    Paulo Maurício
  • 4.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 07:40 AM
    In the WebUI
    1.    Navigate to the Configuration >Management >Certificates > CSR page.
    2.    Click Generate New.
    3.    Enter the following information:
    Table 106 CSR Parameters (Continued)
    Parameter
    Description
    Range
    key
    Length of private/public key.
    1024/2048/4096
    common_name
    Typically, this is the host and domain name, as in aruba-master.yourcompany.com.
    country
    Two-letter ISO country code for the country in which your organization is located.
    state_or_province
    State, province, region, or territory in which your organization is located.
    city
    City in which your organization is located.
    organization
    Name of your organization.
    unit
    Optional field to distinguish a department or other unit within your organization.
    email
    Email address referenced in the CSR.
    Then create a certificate from the CSR on your chosen Certificate Authority (Public or Internal depending on the deployment).
    Then once you have the cert, upload it as you mentioned.
    .. and don't forget to assign the cert to a use: Configuration -> Management -> General
  • 5.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 07:56 AM
    It is recommended to do the CSR / key generation on an external server so you can backup the private key.
  • 6.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 08:20 AM
    James thanks again.
    Today the configuration-->management-->general is default. After upload new cert I will have 2 options (default and new cert), correct? When change and aply, my APs wull reboot?
    Paulo Mauricio
  • 7.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 08:22 AM
    You're correct about changing the cert but your APs will not reboot.
    When you change the cert the web server process will restart and you'll be logged out on the web console.
  • 8.  RE: Captive Portal controller just SHA 2
    Posted Jan 30, 2017 08:31 AM
    Ok James.
    When I do it I post here.
    Thks again.
    Paulo Mauricio
  • 9.  RE: Captive Portal controller just SHA 2
    Posted Feb 09, 2018 02:13 PM
    I have a quetion about the same concern,
    with RSA key i need to choose from "1024/2048/4096" in order to have a certificate that support SHA-2, getting a bit confused as on CSR there is no Dropdown to specify the this option,
    any idea here ?
  • 10.  RE: Captive Portal controller just SHA 2
    Posted Feb 09, 2018 02:19 PM
    Key size is not related to the hashing algorithm.
    A common configuration would be SHA-256 with a 2048-bit key
  • 11.  RE: Captive Portal controller just SHA 2
    Posted Feb 09, 2018 02:30 PM
    hello Cappalli
    thanks for your pro-activity
    i would like to know if SHA-256 is an option to configure from CA side or from controller
    thank you for your help
  • 12.  RE: Captive Portal controller just SHA 2
    Posted Feb 09, 2018 02:34 PM
    A public CA is usually not going to give you the option. They will give you a SHA-256 cert.
  • 13.  RE: Captive Portal controller just SHA 2
    Posted Feb 09, 2018 06:21 PM
    got you !
    so what i need to do is to generate a CSR with 2048 key lenght, and then send it to CA for signature using sha-256
    ==> result will be a certificate that support thumbprint algorithm of SHA-2
    am i right ?
    thank you cappalli for contributions
  • 14.  RE: Captive Portal controller just SHA 2
    Posted Feb 09, 2018 07:28 PM
    Yes, correct.
