I wante to resize the captive portal page on aruba controller v8.x, is there a way to download the files from the controller and customize them.
Aghiles
For that you have to use Clear Pass to do customize pages.
You can create a custom captive portal in the controller with an open-source HTML 5 responsive template.http://html5up.net/verti/
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1649
you can try above link also.
