captive portal design
  • 1.  captive portal design
    Posted May 04, 2014 06:43 PM
    Hi.
    I going to set up captive portal with 3400 controllers and I've got couple of questions.
    Does captive portal require connectivity with DNS server before authentication?
    Does controller need IP address for guest subnet and does controller have to be a gateway or I can use other device as gateway for guest subnet?
    Is it possible to configure DHCP relay on controller for guest subnet?
    Thanks for help,
    #3400
  • 2.  RE: captive portal design
    Posted May 04, 2014 06:47 PM
    @mate78 wrote:
    Hi.
    Does captive portal require connectivity with DNS server before authentication?  - YES
    Does controller need IP address for guest subnet and does controller have to be a gateway or I can use other device as gateway for guest subnet? - Captive Portal on the controller needs an ip address in the subnet of the guest network.  It does not have to be the gateway of the guest network, however.
    Is it possible to configure DHCP relay on controller for guest subnet? - Yes, using the "ip helper-address" command on the controller's interface or on the interface of the gateway on that subnet.
    Thanks for help,
  • 3.  RE: captive portal design
    Posted May 04, 2014 07:04 PM
    OK. I'll try to configure captive portal according to this.
    Thanks again.
  • 4.  RE: captive portal design
    Posted May 04, 2014 09:07 PM
    Lastly, make sure that you use the ip cp-redirect-address command to point to the ip address of the controller on that VLAN:  http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-ip-cp-redirect-address/m-p/236/highlight/true#M49
