Hi Team,
Is possible have captive portal external, unlicensed firewall with clearPass
Your options are very limited without the Firewall license. The user guide says here: http://www.arubanetworks.com/techdocs/ArubaOS_63_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Captive_Portal/Captive_Portal_in_the_Ba.htm what you can configure with just the base license.
Hi, Is possible configure two interfaces in clearpass. Data (Wan), MGMT(LAN).
My user would like gateway, the IP mgmt ClearPass. ClearPass may function as a proxy?
not sure if you tried, but i would really start a new thread about your question eduardo, and in the AAA, NAC, Guest Access & BYOD forum.
