Wireless
captive portal for CPPM Onboarding doesn't work
This thread has been viewed 24 times
  • 1.  captive portal for CPPM Onboarding doesn't work
    Posted 22 days ago
    I configured the entire CPPM part for device onboarding.
    I'm having trouble managing the Mobility controller side (8.10.X). Following the directions, I created an SSID with 802.1X wpa2 authentication pointing to the CPPM server.
    The problem is the captive portal, on all indications it is found that under Authentication -L3 you should find the "onboard" object, which however is missing. I created it by hand and configured the captive portal page.
    The same goes for the BYOD-Provision role, which is already present in all the guides, but I couldn't find it and had to create it manually.
    I tried to check on other Controllers version 8.10.x and none of them have the two objects onboard and BYOD-Provision.
    The problem is that, by doing the test on the SSID, the device connects to the network, takes on the BYOD-Provision role, but there is no way to open the captive portal.
    Has anyone encountered the same problem? Do you have any ideas on what I might be missing?
    On the role, for the sole purpose of testing, I went so far as to open everything (any any), but still the CP does not open.
    By using the CP link manually on the device's browser, the page opens correctly and the user is able to register.
    carabina5
  • 2.  RE: captive portal for CPPM Onboarding doesn't work
    Posted 22 days ago
    Make sure you have PEF licenses in the controller. Then you can configure the access-rules, captive-portal and user-role (initial-role). finally assign the initial-role to the AAA profile.
    watch this video https://www.youtube.com/watch?v=F-4p7cqZzXQ
    • configure an alias for clearpass server
    netdestination clearpass
    host "clearpass ip address"
    • configure acl to allow http and https to clearpass server
    ip access-list session allow-clearpass
    any alias clearpass svc-http permit
    any alias clearpass svc-https permit
    • configure captive portal profile and assign server-group (clearpass) and configure the login-page url
    aaa authentication captive-portal byod
    login-page https://<clearpass-fqdn>/<page-url>
    server-group <clearpass-server-group>
    • configure initial user role
    user-role byod-logon
    access-list session logon-control
    access-list session captiveportal
    captive-portal byod
    • assign initial user-role to the AAA profile
      • aaa profile "byod-aaa-prof"
      • initial-role "byod-logon"
    Note: client device should be able resolve DNS to open captive portal automatically
    Harendra
    ACEX165
  • 3.  RE: captive portal for CPPM Onboarding doesn't work
    Posted 22 days ago
    thanks for the answer, but it seems to not work. By the way, the instructions are for guest, but I need it for BYOD (802.1X auth).
      • configure an alias for clearpass server  done with IP addresses
    • configure acl to allow http and https to clearpass server   done
    • configure captive portal profile and assign server-group (clearpass) and configure the login-page url    done
    • configure initial user role   done
    captive-portal byod
    • assign initial user-role to the AAA profile      done
    Now the client it's redirected to the CP, but it stuck in opening in the browser, it never appear the page.
    Clients in the same vlan (wired) can reach CPPM and open the BYOD login page.
    It seems that the controller is blocking something.
    In the controller I can see that the client receive the role BYOD-Provision and the IP in the correct vlan.
    This is the BYOD-Provision role's policies:
    carabina5
  • 4.  RE: captive portal for CPPM Onboarding doesn't work
    Posted 22 days ago
    One rule is missing in. Byod-provision role to allow https and https to clearpass server that's why browser is not able to open the page.
    Add an acl above the captive-portal rule to allow http and https to your clearpass server.
    If you look at your role configuration, rule count is 0 for cppm acl.
    Harendra
    ACEX165
  • 5.  RE: captive portal for CPPM Onboarding doesn't work
    Posted 21 days ago
    he's making me crazy.
    There are rules within the policy. I created a new one, it has 6 rules inside, but I still see 0 in the role.
    carabina5
  • 6.  RE: captive portal for CPPM Onboarding doesn't work
    Posted 21 days ago
    Harendra, it is working now... I don't know why, rules in the role still 0 for cppm.
    Thank you very much.
    If you know, it is necessary a rule for reach appstore for mobiles in the role?
    carabina5
