Is possible from a controller create their own captive portal to limit connection time or I need ClearPass
It can permit a time limit after establishing a session?
You could time them out with the controller and control access with guest account expiration.
Are you looking for access like: You can connect for 4 hours in a 24 hour period or something like that? I think you would need clearpass for that.
@SGTZ wrote: Is possible from a controller create their own captive portal to limit connection time or I need ClearPass
If you create individual users in the local user database, their expiry time is enforced after the user logs in::
is possible establish time session limit without saving user data in bbdd?
Like Evan W says, anything more complicated and you will need ClearPass Policy Manager.
