Captive portal. Guest-login without informing an email
  • 1.  Captive portal. Guest-login without informing an email
    Posted Feb 23, 2012 10:55 AM
    We are trying to activate both user-login and guest-login access in the same cp page with some specific behavior.
    The idea is that corporate users inform their user/pass (normal behavior) and guest users just click a button and get access, without informing and email. Also we would like to hide de guest-login form and replace it with that button. Is that possible?
    Controller 3600 - Release 6.1.2.4
    Thanks in advance
    Jose
    #3600
  • 2.  RE: Captive portal. Guest-login without informing an email
    Posted Feb 23, 2012 12:05 PM
    you can modify the exsisting captive portal by using following form in the index.html.
    <br><br>
    <b>CLICK ON THE BUTTON BELOW TO LOGIN AS GUEST.</b></font></div>
    <div align="center">
    <br><br><br>
    <form name="form1" method="post" action="/auth/index.html/u">
    <span class="bodytext">
    <input type="hidden" id="email" name="email" type="text" value="user@company.com" class="text" accesskey="e" />
    <input type="hidden" name="cmd" value="authenticate" />
    <input type="submit" name="Login" value="Guest Login" class="button" />
    </span>
    </form>
  • 3.  RE: Captive portal. Guest-login without informing an email
    Posted Feb 23, 2012 12:31 PM
    Many thanks Vinod.
    I appreciate your help.
    Jose
