Hi guys,
I have been working back and forth with Aruba Wireless Support techs for over a month now and haven't been able to successfully implement a Captive Portal page for one of our guest WiFi SSIDs.
I would like to use the "Internal captive portal, no auth or registration" option so the guest users don't have to sign in with a username and password or register their email addresses. I would like to use the Captive Portal template if possible, but I have custom HTML code that I can upload and use our company logo. Is there a directory on the Aruba controllers where we need to go upload the custom HTML code and JPEG image?
I would like all of the mobile devices that connect to the guest WiFi SSID to have the Captive Portal page pop-up on their screen, have the guest users either click on the checkbox to accept the terms and conditions OR click on a button to accept the terms and conditions, and be connected to the guest WiFi SSID with a custom role that I have set up.
Has anybody successfully implemented a internal captive portal with no auth or registration on their Aruba wireless controllers and AOS 8.3.0.2?
I have referenced the PDF doc below and suggested to the Aruba Wireless Support tech that we give it a try.
https://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/10187/1/Custom%20Captive%20Portal%20Web%20Guest%20Access.pdf
Any help would be appreciated!
RH-ML
