Captive Portal issue
  • 1.  Captive Portal issue
    Posted Mar 09, 2012 04:09 AM
    I've just configured 4 AP105's. We have some trouble with the Internal authentication of the Captive Portal.
    When I am connected and filled in my password, I can use the wireless network. But after a couple of minutes, I guess
    10 I have to authenticate myself again. I've configured the Inactivity timeout to 3600 secs and the reauth interval to 12 hours. But I still have to authenticate myself every couple of minutes. Does anyone experience the same problem?
    Greetings
    #3600
  • 2.  RE: Captive Portal issue
    Posted Mar 09, 2012 06:39 AM
    Hello cjoseph,
    Thanks for your quick reply. About the printscreen you posted, is that an interface of a controller? We do not have a controller.
    I only can connect to the AP105 and cannot find anything about security.
    Greetz
  • 3.  RE: Captive Portal issue
    Posted Mar 09, 2012 06:47 AM
    I see, you are using Aruba Instant.  I apologize.
  • 4.  RE: Captive Portal issue
    Posted Mar 09, 2012 06:57 AM
    Thanks for your help so far..
    See attachment for printscreen.
    So when my device losses the connection, I have to reauthenticate again. But when I look to the settings, the reauth interval is 12 hours and the inactivity time out is one hour.
    But when I'm idle for like 20 minutes I have to authenticate again.
  • 5.  RE: Captive Portal issue
    Posted Mar 09, 2012 10:18 AM
    Can you send me "show ap tech-support-dump" and client mac address?
  • 6.  RE: Captive Portal issue
    Posted Mar 12, 2012 03:39 AM
    The mac address is:  7c:c5:37:3e:ad:43
    I think it only happens with ios devices....
    Attachment(s)
    zip
    techsupport.zip   23 KB 1 version
  • 7.  RE: Captive Portal issue
    Posted Mar 12, 2012 07:28 AM
    Can we also get output of "show clients debug"?
  • 8.  RE: Captive Portal issue
    Posted Mar 12, 2012 08:09 AM
    I do not have that option. Can I do this also in CLI?
  • 9.  RE: Captive Portal issue
    Posted Mar 13, 2012 05:54 PM
    Dear customer(mafkees80),
       we are able to reproduce this issue based on your input. We will fix this issue soon and update you once the build is ready.
    reg
    KK
  • 10.  RE: Captive Portal issue
    Posted Mar 14, 2012 06:37 AM
    Thank you for the info! I will wait for an update
    Greetings
    Chris
  • 11.  RE: Captive Portal issue
    Posted Jun 04, 2012 04:03 AM
    Is the update available now?
    Greetz,
  • 12.  RE: Captive Portal issue
    Posted Mar 26, 2013 12:40 PM
    I'm experiencing the same thing on IAP-105's with ClearPass Guest, all on the latest versions of everything.  Was there ever a resolution to this problem?  Guests are being prompted to login again if inactive for less than 3 minutes.
  • 13.  RE: Captive Portal issue
    Posted Mar 12, 2012 08:10 AM
    Yes. This also needs to be done while that client is attached.
  • 14.  RE: Captive Portal issue
    Posted Mar 12, 2012 10:02 AM
    I can't connect with putty or telnet to the AP? Do I have to connect to the console port?
  • 15.  RE: Captive Portal issue
    Posted Mar 12, 2012 03:32 PM
    Go to  Settings > Advanced > Terminal access to enable telnet access to the AP.
