Hello Guys .
I need to change the Log-In Page into the german Language !
Now i have the Problem , if i change the language i have problems with the changes in the Captive Portal Authentication Profile ...
For example if i want to use the Guest Login , and i enable this option , it is not enabled on the Log In Page!
Every change is not working anymore !
If i use the revert to factory default settings option , everything is working fine again !
I really don't know how to fix this problem , even with the user Guide !
The SW is 6.1.2.4 !
I hope you can give me some advices !
BR
