Hi All,
Im struggling to enable LDAP as part of the authentication process for the captive portal, Im hoping ive missed somthing daft that someone can point out to me :catlol:
- The LDAP server settings are good, "Authentication Successful" when running the AAA-test
- The AAA Profile is setup to allow the internal DB and the LDAP server as authenication methods.
When I atempt to login to the capive portal using AD credentials, I get authentication failed, while if I attempt an internal db login it works fine.
Just on the off chance Ive put the ldap server at the top of the list but still, authentication failed @ the portal.
Thanks for your help guys,
