Captive portal login page on Master, but nothing on local?
  • 1.  Captive portal login page on Master, but nothing on local?
    Posted Jan 29, 2014 10:56 AM
    Cant even get the defualt CP page showing on the local controller, nevermind any custom ones.  Works fine on the Master.  I am able to switch between CP on either controller as I have an ap terminating on both and have confirmed that I am connected an in a guest login role on whichver controller I happen to be connected to.
    Not sure where to start, as I had assumed the only config I would have to do on the local would be if I wanted to add custom pages.
    Any suggestions?
  • 2.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 29, 2014 10:57 AM
    Do you have a layer 3 interface on the local for the user subnet?
  • 3.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 29, 2014 11:01 AM
    No.. all user subnets are layer 2 and are trunked to both controllers.
  • 4.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 29, 2014 11:06 AM
    You need to add an IP on the local controller for the redirect to work correctly.
  • 5.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 30, 2014 01:02 AM
    Sorry, but I dont quite follow what you are saying...  An IP for what?
  • 6.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 30, 2014 03:00 AM
    For captive portal to work on the controllers the VLAN interface that is connecting the client will need to have a IP address. Example if you are using VLAN 100 to connect the clients then you will need to set on both controller:-
    vlan 100
    ip address 10.10.100.X subnet mask
  • 7.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 30, 2014 03:10 AM
    lol.. sorry, thought that was a bit too obvious..
    Id assumed there was something a bit more specific I had to do on the local contoller to get CP working!  All ip/vlan related info etc, is fully configured on both boxes.. both accept clients and work ok, just no CP webpage on local (not even default).
  • 8.  RE: Captive portal login page on Master, but nothing on local?
    Posted Jan 30, 2014 07:16 AM
    Are you able to see the captive portal if you navigate to 1.1.1.1 in the web browser?
