Captive Portal Login Page Redirection Not Working
  • 1.  Captive Portal Login Page Redirection Not Working
    Posted Aug 15, 2012 12:02 PM
    We have a provisioning Captive Portal Authentication profile. Our clients can connect to this network however Google / browsers homepage is loading and NOT the "Login Page" we configure.
    I can manually type in the address of the Login Page but ideally we want the browser to redirect to this page.
    Any idea where to start?
  • 2.  RE: Captive Portal Login Page Redirection Not Working
    Posted Aug 15, 2012 12:17 PM
    Some further details -
    Our guest redirect works (using specific guest VLANs) however we are trying to setup a Provisioning page for trusted iPads and devices outside of GPO deployment. These are not working.
    Our client gets an IP and is able to nslookup our controller and can access the redirect page manually (typing in the address) but is NOT automatically being redirected. We have the https://<servername.domain.com/device_provisioning.php in our Login Page field - but it is not redirecting here.
    IF we change the VLANs for this provisioning to match our Guest VLANs the redirection DOES work. It is only when we change this VAP to use the Trusted VLANs that redirection fails.
    Is there code or config we can post that migth help?
  • 3.  RE: Captive Portal Login Page Redirection Not Working
    Posted Aug 15, 2012 01:57 PM
    This looks like a configuration issue. Can you attach your running config here and tell me which VAPs and VLANs are you trying to use?
    The VLAN for which CP login not working isd it L3 (IP on controller) or L2 (no IP on controller) vlan?
  • 4.  RE: Captive Portal Login Page Redirection Not Working
    Posted Aug 15, 2012 03:02 PM
    Found the issue - no Interface for this particular VLAN - adding one solved the Provisioning redirect
  • 5.  RE: Captive Portal Login Page Redirection Not Working
    Posted Aug 15, 2012 04:04 PM
    Your post helped - we didn't have a VLAN Interface for this particular VLAN - once we provided an IP the redirection worked.
  • 6.  RE: Captive Portal Login Page Redirection Not Working
    Posted Aug 15, 2012 04:09 PM
    I am glad  worked...
    Cheers...
  • 7.  RE: Captive Portal Login Page Redirection Not Working
    Posted Jul 30, 2013 02:03 AM
    The Guest Vlan MUST have valid IP address in controller.
