Captive portal login page url returns to default after setting captive portal profile.
  • 1.  Captive portal login page url returns to default after setting captive portal profile.
    Posted Apr 12, 2016 05:21 PM
    I am setting up a captove portal with clearpass and whenever I set the following values on the controller (shown in the picture), one of them always return to default. What am I doing wrong?
    Thanks.
  • 2.  RE: Captive portal login page url returns to default after setting captive portal profile.
    Posted Apr 12, 2016 05:23 PM
    You shouldn't need to do any captive portal customization on the controller
    itself. What are you changing in the customize login config?
  • 3.  RE: Captive portal login page url returns to default after setting captive portal profile.
    Posted Apr 12, 2016 05:30 PM
    The "Customize Login Page" portion only shows you a list of profiles and allows you to cycle through them using the drop down. When you return to the page, it always shows you the default profile by default. Your other settings should not be affected by that.
