Hi all!
I have 2 Aruba 650 controllers configured as master-local without redundancy (HA), it is posible configure the captive portal in master controller only? guest user, capitive portal config, guest-provisioning profile, etc?
what i want is keep this config in the master (bulding 1) if a guest-user goes to local (building 2) he doesn't need to ask for another user and password, and the administrator doesn't need to create a guest user in the local controller because he has already created the user in the master controller.
thanks for your help!
