captive portal must reply within 5 sec?
  • 1.  captive portal must reply within 5 sec?
    Posted Sep 29, 2015 02:48 AM
    Hi, all
    In captive portal process,
    when there is no reply of the HTTP request within 5 sec,
    the session is disconnected.
    Is this IAP's tinyproxy's setting?
    ArubaOS (MODEL: RAP-109), Version 6.4.2.3-4.1.1.2
    regards,
    mitsuhiro nakamura
  • 2.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 06:56 AM
    You might want to try to update your IAP to 4.1.1.8.  That issue might have been fixed already.
  • 3.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 10:02 PM
    Thank you for replying
    I tried the following firmware.
    - ArubaInstant_Pegasus_6.4.2.6-4.1.1.8_50989
    - ArubaInstant_Pegasus_6.4.3.1-4.2.0.0_51112
    but could not solve issue.
  • 4.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 10:03 PM
    How many clients are on your WLAN?
    Are your wireless clients on the same WLAN as your wired clients?
  • 5.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 10:08 PM
    Just 1 client.
    Client IP address is assigned from IAP.
    Client List
    Name IP Address MAC Address OS Network Access Point Channel Type Role Signal Speed (mbps)
    iPhone5s 172.31.99.224 3c:ab:8e:de:9f:89 iPhone CP-TEST 9c:1c:12:cb:6a:48 116+ AN External CP 65(good) 150(good)
    Number of Clients :1
    Info timestamp :425
  • 6.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 10:12 PM
     Have you tried anything else besides an iphone?
  • 7.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 10:31 PM
    No nothing.
    I'm just testing attached config and html.
    Attachment(s)
    txt
    show_run.txt   2 KB 1 version
    txt
    index_php.txt   43 B 1 version
  • 8.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 10:39 PM
    I do not have an IAP to test your config.  What are you trying to do?
  • 9.  RE: captive portal must reply within 5 sec?
    Posted Sep 29, 2015 11:31 PM
    I'm testing external captive portal which takes over 5 sec to reply.
    I'll try to improve captive portal process.
    Thanks anyway.
    regers,
    Mitsuhiro Nakamura
