Captive portal on IAP can supported roaming right?
  • 1.  Captive portal on IAP can supported roaming right?
    Posted Mar 18, 2016 04:10 AM
  • 2.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 18, 2016 05:39 AM
    Within the same cluster.
  • 3.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 19, 2016 12:19 AM
    Hi Colin Joseph,
                     Thank you for reply me. Now the customer use  1 virtual controller but when client mover to other IAP that must authenication again.
                      I serch in KB already and found about WISPr configuration as link below.
    http://community.arubanetworks.com/t5/Controller-less-WLANs/What-is-the-purpose-of-Wireless-Internet-Service-Provider/ta-p/178924
                      WISPr should configuration on this case or not.  If not to do. Please solution for recommend on this case. Thank you .
    Best Regards
  • 4.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 19, 2016 12:34 AM
    So are you saying that there are 2 IAPs in this cluster or only one?  If both IAPs are in the same cluster, there should not be any need to authenticate twice.  If both are in different clusters, the answer is yes.
    What is the use case here and why is wispr an option?
  • 5.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 20, 2016 11:30 PM
    Hi
           I found same cluster but cannot roaming on captive portal. i add configuration already. Please help me to check this configure. I don't know what a mistake on this configure. Thank you.
    Best Regards
    Attachment(s)
    txt
    text.txt   3 KB 1 version
  • 6.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 21, 2016 02:02 AM
    Can I ask why you have both mac-authentication and internal captive portal enabled on the same SSID?
  • 7.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 21, 2016 02:10 AM
    Hi
                Because firstime the customer told me cannot roaming on captive portal that make them try to use MAC authentication for block compain fronm user.
  • 8.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 21, 2016 02:13 AM
    Do you mean the recommendation came from Aruba? Or someone else?
  • 9.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 21, 2016 02:27 AM
    No it's not recommended but the customer try to do something for help user not authentication again when user move to other IAP.
  • 10.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 21, 2016 04:44 AM
    Ok... We should remove mac-authentication; it does not help caching the client's captive portal authentication state for internal captive portal; in fact it would make things worse.
    Before, when only internal captive portal is enabled, and mac-auth is disabled, was the client state not carrying-over during roaming? What behavior did you see exactly?
  • 11.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 21, 2016 07:37 AM
    Ans     Yes, only captive portal is enabled, client authentication again when client move to other place.
    IAP not far from each other.
  • 12.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 22, 2016 05:28 AM
    Hi Colin Joseph,
            What is a mistake on this configuration with out MAC-atuhen because that use for test ?
    For captive portal roaming need enable somthings or not ?
  • 13.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 22, 2016 08:07 AM
    You should not have to enable anything.  Please PM me the tech support from the VC so I can take a look.
  • 14.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 22, 2016 11:23 PM
    Thank you but now the i have inconvinience to get tech support. I will uploade for you in tomorrow.
  • 15.  RE: Captive portal on IAP can supported roaming right?
    Posted Mar 24, 2016 12:51 AM
    I add tech support for you already but dont intereated in MAC configuration. i will reccomend the customer later.
    Attachment(s)
    txt
    target.txt   489 KB 1 version
