Captive portal on IAP without using Clearpass
  • 1.  Captive portal on IAP without using Clearpass
    Posted Jun 04, 2013 04:06 AM
    I saw a previous post about captive portals and aruba instant, but still wasn't quite clear if implementing a terms of service captive portal was possible with only IAPs (and without clearpass).  Also, how much customization can be done on that captive portal page or can that page be located externally.
    I'm looking at using the IAPs for WiFi hotspots managing them via Airwave, but all I want to do is divert the user to a welcome page with terms of service prior to them using the service.
    Jay
  • 2.  RE: Captive portal on IAP without using Clearpass
  • 3.  RE: Captive portal on IAP without using Clearpass
    Posted Jun 04, 2013 07:44 AM
    You may also want to inspire yourself from the following template.
    Paul Gallant, Eng.
    CWNA, CWSP
    Attachment(s)
  • 4.  RE: Captive portal on IAP without using Clearpass
    Posted Feb 06, 2014 10:20 AM
    Here are updated templates using HTML POST.
  • 5.  RE: Captive portal on IAP without using Clearpass
    Posted Feb 06, 2014 10:21 AM
    thanks
