captive portal password change
  • 1.  captive portal password change
    Posted Jun 08, 2015 02:28 PM
    sorry for the probably easy question - but where on the web gui for ArubaOS can i change the captive portal password ?
  • 2.  RE: captive portal password change
    Posted Jun 08, 2015 02:31 PM
    Security > Authentication > Servers > Internal Db
  • 3.  RE: captive portal password change
    If you setup the Captive Portal, it is pointing at a database, either the internal database, or an external one.  If it is the internal database, it should be under configuration> Security> Authentication> Severs> Internal DB.
