captive portal personel background upload
  • 1.  captive portal personel background upload
    Posted Aug 02, 2014 06:48 AM
    hi,,
    am tryin to upload personel background image on controller captive portal, but the image doesnt fit the screeen, how can i fix this issue ,its JPG format already,
    but  i cant see the all image on the captive portal
    kindly fin the image attachment
    thank you
  • 2.  RE: captive portal personel background upload
    Posted Aug 02, 2014 06:54 AM
    Try to reduce the image size in something like Paint or Microsoft picture tools.
  • 3.  RE: captive portal personel background upload
    Posted Aug 02, 2014 06:56 AM
    i did, and it works, but  the other half of screen on the captive portal is black
  • 4.  RE: captive portal personel background upload
    Posted Aug 02, 2014 06:59 AM
    oohhh,, ok,,,  it works now,,,, thanks :D
  • 5.  RE: captive portal personel background upload
    Posted Aug 02, 2014 08:55 AM
    If the background is black, specify white as your background color when you load your custom JPEG by putitng #FFFFFF in teh Custom page background color field.  This will color the edge outside of your jpeg white.
