Captive Portal Problems
  • 1.  Captive Portal Problems
    Posted Jun 14, 2012 03:12 PM
    Hey Guys, Maybe someone can help me with my problem with captive portal.
    I have a controller that has several Vlans
    Example:
    Vlan 1, 10.56.1.40
    Vlan 2, 100.56.120.40 Employee
    Vlan 3, 172.16.1.40 Guest
    Port is setup as 1 Native and also allows 2 and 3
    Depending on the SSID, it will place the client into the appropriate vlan and the client grabs a correct IP. The controller is not the DHCP server.
    My Employee clients are able to 802.1X authenticate and it is all good.
    My Guest clients can get an IP and just sit there. I “CAN” ping anything on the network. But when I try to http or https, the redirect does not work. I can apply Any any any to the top of the ACL and I can reach everything. So my dstNating is not working with the redirect.
    Another tidbit,If I:
    Create Vlan 4 192.168.1.1
    Enable src nat
    Do not add to the trunk port
    Create a DHCP Scope, 192.168.1.2-254
    Apply this to the guest VAP
    Captive portal will work, but this is not how we want it.
    I am using guest-logon and guest as my roles.
    user-role guest-logon
     access-list session logon-control
     access-list session captiveportal
    user-role guest
     access-list session http-acl
     access-list session https-acl
     access-list session dhcp-acl
     access-list session icmp-acl
     access-list session dns-acl
    ip access-list session logon-control
      user any udp 68  deny
      any any svc-icmp  permit
      any any svc-dns  permit
      any any svc-dhcp  permit
      any any svc-natt  permit
    ip access-list session captiveportal
      user   alias controller svc-https  dst-nat 8081
      user any svc-http  dst-nat 8080
      user any svc-https  dst-nat 8081
      user any svc-http-proxy1  dst-nat 8088
      user any svc-http-proxy2  dst-nat 8088
      user any svc-http-proxy3  dst-nat 8088
    Anything would be great, thanks.
    Also, what is the url of the captive portal page? can this url be reached by computers already on the network?
  • 2.  RE: Captive Portal Problems
    Posted Jun 14, 2012 04:33 PM
  • 3.  RE: Captive Portal Problems
    Posted Jun 14, 2012 05:08 PM
    Thanks, It is the master Vlan 1 address, 10.56.1.40. But this should be fine because the vlan 3 is routable to vlan 1. Even though the guest clients do not get redirected to the captive portal, they can still ping 10.56.1.40.
    This should still work correct?
  • 4.  RE: Captive Portal Problems
    Posted Jun 14, 2012 05:34 PM
    Do you have the Captive Portal Profile enabled on your guest-logon role.
    Example config below:
     captive-portal "guestnet"
     access-list session allow-amigopod
     access-list session v6-logon-control
     access-list session captiveportal6
  • 5.  RE: Captive Portal Problems
    Posted Jun 14, 2012 05:37 PM
    Yes. Everything. To do with ACLs in the controller is correct I believe. If i use all the same profiles but change the vlans to 4 captive portal works.
  • 6.  RE: Captive Portal Problems
    Posted Jun 14, 2012 06:04 PM
    Yes the full role is,
       captive-portal "DistrictGuestWlan-cp_prof"
  • 7.  RE: Captive Portal Problems
    Posted Jun 17, 2012 08:13 PM
    Are you able to reach DNS from the client(try to do nslookup to google.com)?
    Also, try to find the datapath session for the client when you pass traffic from the client (show datapath session table <IP address of the client>) . See if there is any "D"-DENY or "Y"-NO sync flag.
    To isolate the DNS problem, try to put IP address of any website in the URL and see if it re-directs.
    Captive portal URL : https://securelogin.arubanetworks.com.
    Pradeep
  • 8.  RE: Captive Portal Problems
    Posted Apr 18, 2016 07:36 PM
    Hi, my CP is not redirecting too. I can get to the captive portal page but I have to type it.
     YES
     YES, I see some flags  like:
    10.110.30.190   132.245.75.114  6    64726 443    0/0  0    0   1   tunnel 744  43   0          0          NYCI
    10.110.30.190   204.79.197.200  6    64731 80     0/0  0    0   0   tunnel 744  33   0          0          NYC
    132.245.46.130  10.110.30.190   6    443   64737  0/0  0    0   0   0/0/5       e    1          52         FDC
    134.71.2.50     10.110.30.190   6    8081  64744  0/0  0    0   0   tunnel 744  2    1          52         SI
    134.71.2.50     10.110.30.190   6    8081  64738  0/0  0    0   0   tunnel 744  18   1          52         SI
    132.245.82.50   10.110.30.190   6    443   64744  0/0  0    0   0   0/0/5       2    0          0          FDYC
    134.71.2.50     10.110.30.190   6    8081  64740  0/0  0    0   0   tunnel 744  b    4          208        SI
    10.110.30.190   204.79.197.200  6    64736 80     0/0  0    0   0   tunnel 744  1d   0          0          NYC
    10.110.30.190   204.79.197.200  6    64742 80     0/0  0    0   0   tunnel 744  7    2          104        NYC
    134.71.2.50     10.110.30.190   6    8081  64734  0/0  0    0   1   tunnel 744  27   0          0          SI
    134.71.2.50     10.110.30.190   6    8081  64714  0/0  0    0   0   local       7    0          0          FDYC
     This is the problem. It won't redirect.
    I can ping this. I am able to access this but I have to type it manual on web browser.
