Captive Portal Re-direct
  • 1.  Captive Portal Re-direct
    Posted Apr 19, 2012 12:52 PM
    I basically followed this KB article to setup a guest network :
    http://support.arubanetworks.com/Default.aspx?tabid=111
    My thinking is to have a guest network that requires a WPA-PSK.  Once a user enters that PSK they are redirected to a captive portal page with acceptable use policy with a button that says "I AGREE" at the bottom.  User clicks that and goes about their merry way.
    Everything is working except the "I AGREE" button.  When i click it just loops me right back to the same page.  I'm not a HTML guy but i'm thinking it has somethign to do with this line:
    <form name="form1" method="post" action="/auth/index.html/u">
    Not sure how to get that "I AGREE" button working
    ANy ideas?
  • 2.  RE: Captive Portal Re-direct
    Posted Apr 19, 2012 04:06 PM
    What version of ArubaOS?  Did you make a custom HTML page?
  • 3.  RE: Captive Portal Re-direct
    Posted Apr 23, 2012 09:56 AM
    3400 Controller
    AP 105's
    ArubaOS 6.1.2.2
    I created a custom HTML page that basically has acceptable use policy with an "I Agree" button at the bottom.  Once a user clicks that I AGREE button they should be able to freely browse the internet.
    My HTML :
    <META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1">
    <!DOCTYPE HTML PUBLIC"-//W3C//DTD HTML 4.01 Transitional//EN">
    <html>
    <head>
    <title>Public wireless Internet access</title>
    <style type="text/css">
    body {
    font-family: Verdana, Arial, Helvetica, sans-serif;
    font-size: 12px;
    background-color: #FFFFFF;
    margin: 10px;
    padding: 10px;
    h1 { font-size: 16px; font-weight: bold; }
    h2 { font-size: 14px; font-weight: bold; }
    p, ul, li, input { }
    </style>
    </head>
    <body>
    <h1 align="center">Company C<br/>Guest Wireless Access Acceptable Use Policy</h1>
    <p>
    This Policy is a guide to the acceptable use of the Company C Guest Wireless network facilities and services.
    <br/><br/>
    Any individual connected to the Guest Wireless Network in order to use it directly or to connect to any other network(s), must comply with this policy, the stated purposes and Acceptable Use policies of any other network(s) or host(s) used, and all applicable laws, rules, and regulations.
    <br/><br/>
    COMPANY C MAKES NO REPRESENTATIONS OR WARRANTIES CONCERNING THE AVAILABILITY OR SECURITY OF THE GUEST WIRELESS NETWORK, AND ALL USE IS PROVIDED ON AN AS-IS BASIS. BY USING THE GUEST WIRELESS NETWORK YOU AGREE TO DEFEND, INDEMNIFY, AND HOLD HARMLESS COMPANY C FOR ANY LOSSES OR DAMAGES THAT MAY RESULT FROM YOUR USE OF THE GUEST WIRELESS NETWORK.
    <br/><br/>
    Company C takes no responsibility and assumes no liability for any content uploaded, shared, transmitted, or downloaded by you or any third party, or for anything you may encounter or any data that may be lost or compromised while connected to the Guest Wireless Network.
    <br/><br/>
    Company C reserves the right to disconnect any user at any time and for any reason. The Guest Wireless Network is provided as a courtesy to allow our guests access to the internet. Users will not be given access to the Company C intranet or permission to install any software on our computers.
    <br/><br/>
    Inappropriate use of the Guest Wireless Network is not permitted. This policy does not enumerate all possible inappropriate uses but rather presents some guidelines (listed below) that COmpany C may at any time use to make a determination that a particular use is inappropriate:
    </p>
    <ul>
    <li>Users must respect the privacy and intellectual property rights of others.</li>
    <li>Users must respect the integrity of our network and any other public or private computing and network systems.</li>
    <li>Use of the Guest Wireless Network for malicious, fraudulent, or misrepresentative purposes is prohibited.</li>
    <li>The Guest Wireless Network may not be used in a manner that precludes or hampers other users access to the Guest Wireless Network or other any other networks.</li>
    <li>Nothing may be installed or used that modifies, disrupts, or interferes in any way with service for any user, host, or network.</li>
    </ul>
    <br><br>
    <b>CLICK ON THE BUTTON BELOW TO ACCEPT THE ABOVE POLICY TERMS.</b></font></div>
    <div align="center">
    <br><br><br>
    <span class="bodytext">
    <input type="hidden" id="email" name="email" type="text" value="user@company.com" class="text" accesskey="e" />
    <input type="hidden" name="cmd" value="authenticate" />
    <input type="submit" name="Login" value="I ACCEPT" class="button" />
    </span>
    </form>
    </div>
    </body>
    </html
  • 4.  RE: Captive Portal Re-direct
    Posted Aug 27, 2012 03:53 AM
    hi mike,
    have you managed to solve the issue ?
    i'm encountering same proble here
    rgd
    ylt
  • 5.  RE: Captive Portal Re-direct
    Posted Aug 27, 2012 03:55 AM
    yelynntun,
    Did you try to get it working with a regular captive portal page first?  You should try that before applying the custom page.
  • 6.  RE: Captive Portal Re-direct
    Posted Aug 27, 2012 04:26 AM
    hi collin,
    thanks for the prompt reply.
    I just manage to get it work with custom portal.
    There are three things I amend but I've no idea which one solved my problem
    i) enable guest logon in custom CP profile
    ii) add "user any udp 68 deny" ip acl session on the top which applied to "guest" role
    iii) add acl statement  "user alias mswitch svc-https dst-nat 8081" in cp acl session (But i already have for http dst-nat 8080)
    do you have any idea which exactly sort it out ?
    best wishes
    ylt
  • 7.  RE: Captive Portal Re-direct
    Posted Aug 27, 2012 04:28 AM
    I and III are necessary.
  • 8.  RE: Captive Portal Re-direct
    Posted Apr 23, 2012 10:37 AM
    When you have the CP page up, do a "show user" on the controller and see what role the user is in.  Is it the guest-logon role?  Then, click the accept button.  Did the user switch to the guest role?  If so, it is an ACL problem.  If not, it is an authentication problem.
