Can anyone share the certificate types that are to be installed in Cisco switches for authenticating LAN users using clearpass guest?
Krishna sairam
For wired guest on Cisco L2 switches, you don't need certificates on the switch as far as I know.
Please check the ClearPass Solution Guide for Wired Policy Enforcement, as it has a scenario for wired guest, which you probably can just follow.
