Port 4343 is for the WebUI of your WLAN (AP/controller). So it looks like whatever is under the blue box (IP or hostname) is pointing to your AP/VC/controller, and not to ClearPass; or ClearPass is not excluded from the redirection.
There is a video on guest server vs controller initiated that shows how to debug the captive portal process step by step with the browser developer tools. That may be a good one to have a look at.
Original Message:
Sent: Jul 31, 2024 04:19 AM
Subject: Captive portal redirection with port 4343
Hi All, I am using Aruba IAP version 8.10.
I'm in the process of learning CPPM captive portal(CPPM version is 6.10)
With the guide from Airheads Broadcasting youtube series Aruba ClearPass Workshop (2021) - Guest Access #3 - Wireless Guest (finishing up)
I found that my captive portal redirection always contain port 4343 instead of the configured port 443.
Captive portal doesn't show up.
Need help on this.
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/89ec833706c94bb894063f811ba10b81.png)
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/8fef6477d87b435686154a6b6b98265d.png)
