Currently we have a customer with captive portal network authentication.
trying to connect with Android device, getting an IP address and login through the captive portal - all works fine.
While trying to roam from one AP to another the client gets "Internet Connection error" and unable to reconnect again.
The client is unable to reconnect until i'm disconnect it from the controller.
From the tests i've done it's seems something related to the IP address, because while using static IP this problem doesn't occurs.
Any ideas how to solve this issue?
Thx
Tal
