is there a way to change the wording on the captive portal screen..
i do not want to see the email address box..
just basiclly want the people to read our agreement about terms of use and that is all..
any help word be great..
If you are using a controller. You would need to go to Configuration> Security> Authentication> L2 Authentication. Select your Captive Portal authentication profile. Make sure that Guest Login and User Login is unchecked. Also make sure that "show acceptable use policy page" is checked:
yes sorry i am using a aruba 3600 model controller.
running 6.1.3.2
