Captive Portal Setup
  • 1.  Captive Portal Setup
    Posted Dec 11, 2013 05:23 PM
    I am finally conceeding to defeat....
    I followed the instructions set in here (Aruba OS 6.2) and still have been unable to get my captive portal to work...
    I have attempted the Guest-logon role, the Guest role, a combination of those two minus the v6, and have setup my own customized captive portal.
    From what I have read online, if there is a DNS issue I will know by going to 1.1.1.1, and it is supposed to work....
    I have now basically done two setups for the CP -- one on my own, and one following the instructions as best I could for what I need....
    From what I can tell, it should have worked....
    Does anyone have any suggestions? I'm sure it will be something simply stupid on my part but I have not been able to figure out what it may be.... I have attached snippets of the code in hope that someone might see something....
    Anyone have any suggestions?
    Thank you!!!!!!
    #I basically added in the "guest-logon" and the "guest" combined together....in hopes that it would do something...
    user-role WC-cp_prof
    vlan 111
    reauthentication-interval 120
    captive-portal "WC-cp_prof"
    access-list session logon-control
    access-list session captiveportal
    access-list session v6-logon-control
    access-list session captiveportal6
    access-list session http-acl
    access-list session https-acl
    access-list session dhcp-acl
    access-list session icmp-acl
    access-list session dns-acl
    aaa profile "WC-aaa_prof"
    initial-role "WC-cp_prof"
    authentication-mac "default"
    # the only odd thing that i see is that my current GUI says the default role is guest -- not guest-logon
    aaa authentication captive-portal "WC-cp_prof"
    server-group "WC_srvgrp-xdb84"
    guest-logon
    protocol-http
    logon-wait minimum-delay 2
    login-page "/upload/custom/WC-cp_prof/R-guest_2013-08-09-2.html"
    switchip-in-redirection-url
    wlan virtual-ap "WC-vap_prof"
    aaa-profile "WC-aaa_prof"
    ssid-profile "WC-ssid_prof"
    vlan 111
    ap-group "Testing"
  • 2.  RE: Captive Portal Setup
    Posted Dec 11, 2013 05:26 PM
    Do you have an IP address on the controller for the user subnet?
    Captive portal needs a layer 3 interface in the subnet to perform the
    dst-nat.
  • 3.  RE: Captive Portal Setup
    Posted Dec 11, 2013 05:49 PM
    As I said...... something stupidly simple....
    It works....... as in the page appears.... Now I have to work on configuring the display URL......
    Thank you!!!!!!!
    ~Lisa
