Captive Portal slow / timeout
  • 1.  Captive Portal slow / timeout
    Posted Apr 25, 2013 03:48 AM
    I don't know if this should be posted here or in the security section, but here goes:
    We have a school, which uses Captive Portal for authentication for all students.
    The controller is a 3400 running 6.1.2.7
    Whenever the students starts class, roughly at the same time, they all try to validate through CP.
    We're talking about 2-300 simultaneous logins. The CP is either extremely slow or simply timing out.
    I'm guessing the controller can't handle the load, so what are my options ?
    I tried convincing them to switch to 802.1X for authentication, but apparently that's not an option...
    Can I tweak the controller in any way, or should it be able to handle this amount of connections ?
    Regards
    Kevin
    #3400
  • 2.  RE: Captive Portal slow / timeout
    Posted Apr 25, 2013 06:16 AM
    You should first consider increasing the number of supported connections:
    (Aruba3600) #show web-server
    Web Server Configuration
    Parameter                                      Value
    Cipher Suite Strength                          high
    SSL/TLS Protocol Config                        sslv3 tlsv1
    Switch Certificate                             default
    Captive Portal Certificate                     default
    Management user's WebUI access method          username/password
    User session timeout <30-3600> (seconds)       900
    Maximum supported concurrent clients <25-320>  25
    Enable WebUI access on HTTPS port (443)        false
    (Aruba3600) (Web Server Configuration) #?
    captive-portal-cert     Certificate name configured under certificate
                            manager
    ciphers                 Configure cipher suite strength. Default is high
    mgmt-auth               Configure management user's WebUI access method,
                            either username/password authentication or
                            certificate authentication or both. Default is
    no                      Delete Command
    session-timeout         Configure user's WebUI session timeout <30-3600>
                            (seconds)
    ssl-protocol            SSL/TLS Protocol Config
    switch-cert             Certificate name configured under certificate
                            manager
    web-https-port-443      Enable WebUI access on HTTPS port (443)
    web-max-clients         Configure web servers' maximum supported concurrent
                            clients <25-320>
    (Aruba3600) (Web Server Configuration) #web-max-clients
     In addition, you could:
    - Consder upgrading the older code
    - Moving some clients to 802.1x as a pilot to decrease the reliance on the captive portal
    - Make sure you have "Drop Broadcast and Multicast" enabled on all of your Virtual APs
  • 3.  RE: Captive Portal slow / timeout
    Posted Apr 25, 2013 08:03 AM
    Thank you for the quick reply, Colin. I did NOT know about the web-max-clients command.
    I increased it to 100, that should hopefully do the trick.
    the Drop Broadcast and Multicast was already enabled.
    Will let you know when i get a status back, if increasing web clients helped :)
    Regards
    Kevin
  • 4.  RE: Captive Portal slow / timeout
    Posted Apr 25, 2013 08:13 AM
    Kevin,
    Increasing that number just deals with the web server only serving 25 clients at a time being the bottleneck.  There will be increased memory requirements on the controller as a result.  Please consider upgrading the code because there are hundreds of bug fixes between the code you are on to where we are today.
  • 5.  RE: Captive Portal slow / timeout
    Posted Apr 25, 2013 08:16 AM
    I will try to get the code updated ASAP.
    BTW, any recommended code to put on it ? Looking for a stable release, doesnt have to be the latest and greatest. :)
  • 6.  RE: Captive Portal slow / timeout
    Posted Apr 25, 2013 08:26 AM
    6.1.3.7.
    You could also get a recommendation from TAC depending on what you are doing, but 6.1.3.7 is the most conservative, up to date option.
  • 7.  RE: Captive Portal slow / timeout
    Posted May 24, 2013 06:56 AM
    First day after upgrading controller and increasing number of concurrent sessions. Everything went smooth.
    Thank you
    /Kevin
  • 8.  RE: Captive Portal slow / timeout
    Posted Apr 26, 2013 05:41 PM
    Is there a command to find out how many clients are currently consuming a connection to captive portal?  I can do a show user-table essid SSID_name and look for all users with the guest-logon role, which I assume would give me what I'm looking for, right?
