Hi - Can anyone confirm whether captive portal in split tunnel mode will work with a local DHCP server and a local default gateway?
The AP is on a network which the controller can reach.
@steveh_2001 wrote: Hi - Can anyone confirm whether captive tunnel in split tunnel mode will work with a local DHCP server and a local default gateway? The AP is on a network which the controller can reach. Thanks
It will not.
