Captive Portal Sponsor Email Login doesn't work
  • 1.  Captive Portal Sponsor Email Login doesn't work
    Posted Dec 19, 2017 02:39 PM
    I have setup a Captive Portal page where users can send a sponsor an email to be approved for a guest login. The sponsor is sent an email with a link to the /guest/auth_login.php page where the sponsor logs in using their domain credentials and the service checks to make sure they are a memberOf the "Guest_Sponsor" group. When the sponsor logs in, the access tracker shows that their login was accepted, but they are told their usename/password is incorrect and the Guest user is not authenticated.
    I used a generic Aruba Application Authentication service to handle the login with the service rule just set to "Application Name EQUALS Guest" and they are given the [Allow Application Access Profile] if it is determined they are part of the "Guest_Sponsor" domain group.
     I am not sure where I went wrong here, are there any guides to setting up this email login?
