Captive portal timeout issues
  • 1.  Captive portal timeout issues
    Posted Dec 16, 2011 06:56 PM
    I hate to post this, but I'm new to WLAN configuration so I'm trying to find where to start.(Not new to general network config)
    I have an Aruba 650 controller configured for guest access via the built in Aruba captive portal, all is working OK with one exception.  Users note that when they lose connection(leave building, sleep device, etc), they always have to re-do the captive portal login.  Is there any way to have sessions last longer when using the built in guest access?
    As an example, I have a user reporting that if they walk outside far enough for signal to drop to 0, then return into the building less than a minute or 2 later, they have to go through the disclaimer page again.
    Any leads on troubleshooting would be appreciated.
  • 2.  RE: Captive portal timeout issues
    Posted Dec 16, 2011 09:24 PM
    Users should remain 'authenticated' for the duration of the timeout set under:
    Configuration/Authentication/Advanced
    Under this screen you have the ability to set various timeout values.    You will want to 'bump up'  "user idle timeout" to reduce the number of times the captive portal pops-up to the users.
    I would look at what its currently at and then set for something manageable (say 15 minutes) initially to see how the user community experience improves.
  • 3.  RE: Captive portal timeout issues
    Posted Jan 11, 2012 05:24 AM
    Does anyone know where to find this setting on the 3200 controller? We are having exactly t he same issues. As soon as a user disconnects or connects to another network, then back again, they have to re-authenticate.
  • 4.  RE: Captive portal timeout issues
    Posted Jan 11, 2012 06:24 AM
    Try:
  • 5.  RE: Captive portal timeout issues
    Posted Jan 24, 2012 10:01 AM
    Nice 1. Thanks
  • 6.  RE: Captive portal timeout issues
    Posted Mar 12, 2012 02:23 AM
    Hi
    Is there a way to change the idle timeout value to a greater value than 5 minutes?
  • 7.  RE: Captive portal timeout issues
    Posted Mar 12, 2012 03:07 AM
    All you should have to do, is change the value in the option in the previous screenshot to something greater. The most you can set is 15300 seconds (or about 4.5 hours).
    I noticed some v6 versions have a bug in the gui where it asks you "interim stats" even though you didn't ask or need to. To get around this, I'd telnet/ssh into the controller and do "aaa timers idle-timeout X seconds" from config mode. This work fine. I'd recommend not setting this too high on busy controllers, or you'll start burdening them with lots of legacy session information about transient devices.
    However, one additional tip... I saw exactly what your seeing for quite a few customers. I also found that setting the dos prevention feature under the relevant VAP helped. Why? Well a lot of client devices send a disassociate message when going to sleep or whatever. When they do, this tells the controller they've gone and the user session is booted out anyway (regardless of timers). To fix, enabling dos-prevention tells the controller not to pay attention to the dis-associate message from the device. Try it out.
    wlan virtual-ap "default"
     dos-prevention
  • 8.  RE: Captive portal timeout issues
    Posted Mar 12, 2012 11:53 AM
    Following are the commands to increase the user-idle timeout
    Current timers:
    (master) #show aaa timers
    User idle timeout = 300 seconds
    Auth Server dead time = 10 minutes
    Logon user lifetime = 5 minutes
    User Interim stats frequency = 600 seconds
    Set the user-idle timeout to 10 minutes.
    (master) (config) #aaa timers idle-timeout 600 seconds
    (master) (config) #show aaa timers
    User idle timeout = 600 seconds
  • 9.  RE: Captive portal timeout issues
    Posted Jan 09, 2017 02:53 AM
    hello Everyone,
    I have depolyed 7210 Aruba Controller with captive portal service, IPhones are having issue with Portal pages, the portal page suddenly disappear and user is disconnected from the network, i tried many things  but none of the soultion was permanant and its happening again and again, if anyone could advise how to resolve issue.
    Regards
