Captive portal user should disable after three attemt and captcha
  • 1.  Captive portal user should disable after three attemt and captcha
    Posted Nov 16, 2015 10:37 AM
    I hv Aruba controller 7210 (AOS 6.4.8) and CPPM 5K OS 6.4.2
    My requirement is..
    1) For Guest SSID captive portal login once user filled up correct credential and click "Ok" it should ask for "captcha" which will be display on the captive portal page for authentication.
    (Please suggest if i require CPPM guest license for my requirement/ can i use enterprise lic. for upto 25 guest users?)
    2) After 3 failed attempt Guest user should block(Is there any default time limit or i need to manually enable user after disabled?)
    Thank You..
  • 2.  RE: Captive portal user should disable after three attemt and captcha
    Posted Dec 20, 2015 08:35 AM
    sounds more like a question for the AAA section.
    can't fully help you. captcha aren't built in available i believe. but with an external page a lot is possible.
    guest licening is needed for auth attempts, so if you expect more then 25 guests then you should have more then the built in one.
    all this sounds quite unfriendly for guest access, are you sure you want to let the users jump through these hoops?
