Captive Portal using local database question
  • 1.  Captive Portal using local database question
    Posted Feb 24, 2012 10:02 PM
    We are currently providing guest access at remote sites through a RAP-5WG.  In order to prevent the entire neighborhood from accessing we made a user account on the local database and provided the sites with the username/password to provide to users who want access.
    My question is, can multiple users use this single username/password to access the guest network at the same time?  Or will each guest user need a seperate username/password?
  • 2.  RE: Captive Portal using local database question
    Posted Feb 24, 2012 10:05 PM
    Yes, multiple users can use the same username and password, unless you enable the "Allow only one active user session" option in the Captive Portal Authentication Profile.
  • 3.  RE: Captive Portal using local database question
    Posted Feb 24, 2012 11:45 PM
    I just checked the Captive Portal Authentication profile and I don't see this option.  Can you tell me exactly where this option is available?  Thanks.
  • 4.  RE: Captive Portal using local database question
    Posted Feb 25, 2012 12:22 AM
    The Captive Portal Authentication Profile.
  • 5.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 01:36 AM
    I checked the profile and there is no such option.
  • 6.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 06:33 AM
    I apologize.  What version of ArubaOS do you have?
  • 7.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 05:06 PM
    Version 3.3.2.18-rn-3.1.3
  • 8.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 06:06 PM
    Only supported on ArubaOS 5.x and above.  Any reason you are still on Version 3.3.2.18-rn-3.1.3?
  • 9.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 06:30 PM
    So does this mean that only one user can log in at a time with that username/password?
    We have a big environment that upgrades are not easy to do without bringing alot of people down.  We are planning the upgrade right now to avoid other issues as well.
  • 10.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 06:31 PM
    Only one user with that username, only through captive portal.
  • 11.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 07:52 PM
    Just to verify, on the current 3 code that we are on, using the internal db, only one user can use the username/password at a time?  With the newer code 5/6, multiple users can use the same username/password?  All through Captive Portal of course.
  • 12.  RE: Captive Portal using local database question
    Posted Feb 27, 2012 08:04 PM
    Any device can attach to the network with a valid username and password.  There is an option in 5.x and above to not allow users to login with a username that already exists in the user table.
