Captive portal vs VPN
  • 1.  Captive portal vs VPN
    Posted Mar 03, 2011 03:34 PM
    I have a guest access using Captive portal.
    Everything seems to work, web, pop, imap, etc... but there is one problem, I can't get uers to connect to their VPN (in that case "Contivity VPN client" from Nortel).
    I'm 99 % sure the problem is the Captive portal because if I use another method of authentication (like wpa) then everything works.
    Are they any ports that are blocked with captive portal ?
    Or do you have another idea ?
    thanks
    sorry for my english
  • 2.  RE: Captive portal vs VPN
    Posted Mar 03, 2011 08:15 PM
    Which role is the Captive Portal user in ? Is it Guest ? If yes, then
    that explains what you are seeing. The default Guest role does not
    allow VPN. Every installation I do, I add VPN to the guest role ;)
    If its not guest, which role ?
  • 3.  RE: Captive portal vs VPN
    Posted Mar 03, 2011 08:51 PM
    yes it's guest
    I'm sorry, I'm really new at aruba products...
    what is the easiest way to add vpn to this role ??
    aruba controller 500
    thanks
  • 4.  RE: Captive portal vs VPN
    Posted Mar 03, 2011 10:36 PM
    No worries. Here is the configuration I typically leverage when I am
    doing installations and also provide to folks I work with in my area to
    make their installs go efficiently.
    Step #1 - The policy, apply from the command line of the controller,
    under the config t mode
    ip access-list session VPN-Clients
    user any svc-l2tp permit
    user any svc-esp permit
    user any svc-ike permit
    user any tcp 17 permit
    user any udp 51 permit
    user any udp 4500 permit
    user any tcp 10000 10001 permit
    user any udp 10000 10001 permit
    user any svc-pptp permit
    user any svc-gre permit
    Step #2 -- Associate the new policy with the guest account as follows
    (also from command line)
    user-role guest
    Step #3 -- Your users, in the guest role, should now have full VPN
    capabilities, regardless of the device or client they are using
    (Nortel(R.I.P.) included) :)
    JF
  • 5.  RE: Captive portal vs VPN
    user-role guest
    JF
  • 6.  RE: Captive portal vs VPN
    Posted Mar 07, 2011 10:13 AM
    Thank you very much
    that just did the trick !
    thanks again !
  • 7.  RE: Captive portal vs VPN
    Posted Mar 07, 2011 10:32 AM
    Glad it worked out!
    You have happy guests now :)
  • 8.  RE: Captive portal vs VPN
    Posted Mar 07, 2011 02:14 PM
    Glad it worked out!
    yes they are !
    As you seems to know well the product, instead of using internal database for the Captive portal users/passwords, I suppose it's possible to use a radius server ?
    question 2 : do you know if there is a way to automatically open browser on the captive portal when user connect to the network ?
    edit : ok I found the place in the web interface for the first question.
  • 9.  RE: Captive portal vs VPN
    Posted Jun 07, 2011 09:19 AM
    It is the user that opens the browser which then redirects to the Captive Portal page.
    You can configure it to direct to a specific page after they have entered their credentials by adding it to the Captive portal config,
    aaa authentication captive-portal "Guest"
    welcome-page http://someaddress.com
    Hope this helps
  • 10.  RE: Captive portal vs VPN
    Posted Jun 07, 2011 11:13 AM
    For typical desktop operating systems that is correct. Many of the smart phone operating systems will attempt to ping via http an Internet connected resource upon successful network association in order to see if they have Internet connectivity. Apple iOS for instance will try to ping apple.com, and if necessary will auto-launch a browser to complete the captive portal authentication.
    Still, the action is initiated by the client (user or device), not by the wireless infrastructure.
  • 11.  RE: Captive portal vs VPN
    Posted Nov 17, 2011 04:09 PM
    JF - I was just checking your ACL and these two entries:
    What are these?  I think with UDP 51 you were going for AH, which IP protocol 51.  Not sure what you were going for with tcp 17 though.
    For AH, you want:
    user any 51 permit
  • 12.  RE: Captive portal vs VPN
    Posted Nov 19, 2011 10:28 PM
    Hi Mike,
    Thanks for the note.  Good eyes :)
    My policy (as-is) is working at many a site... but adapting it on the 51 will work as well (your config is a superset of my own for that port).  Thanks for the feedback.
    As for TCP port 17... that is a fun one!      It's for Nortel Contivity VPN client (blast from the past...but still alive in the wild).   It brings up a pop-up message called message of the day / quote of the day.   If the port is blocked the client will refuse to complete the VPN transaction.
    JF
