Captive Portal Welcome Page
  • 1.  Captive Portal Welcome Page
    Posted Mar 05, 2013 02:15 AM
    Can we disable the page that comes when guest sign in to captive portal and it asked them to wait for 10 seconds. we dont want that page to come and guest should directly get the internet without any delay.
  • 2.  RE: Captive Portal Welcome Page
    Posted Mar 05, 2013 06:47 AM
    You can change the redirect timer.  It is located in the Captive Portal profile; called Redirect Pause.  0 will disable it.
  • 3.  RE: Captive Portal Welcome Page
    Posted Mar 05, 2013 09:43 AM
    Got that thank you...
  • 4.  RE: Captive Portal Welcome Page
    Posted Mar 05, 2013 12:01 PM
    change to 0 but page is still showing redirect page :( is their any other option associated with it ??
  • 5.  RE: Captive Portal Welcome Page
    Posted Mar 05, 2013 12:23 PM
    - did you make the change to the right captive portal profile?
    - after the change; how many seconds do you see it for now?
    - try changing to 1 second; what is the result?
  • 6.  RE: Captive Portal Welcome Page
    Posted Mar 06, 2013 10:20 AM
    Yup its on right captive profile
    It didn't show any time now and wait on welcome page until i click on to the link showing " redirect to destination" of like this.
    And this is even worse then before
    will check it by tommorrow and will let you know
    thank you for your support
