Captive portal with Fortigate
  • 1.  Captive portal with Fortigate
    Posted Jan 14, 2018 10:03 AM
    I am trying to create a captive portal page where the users should accept the terms.
    At the website of Fortigate I have found the following:
    http://cookbook.fortinet.com/using-an-external-captive-portal-for-wifi-security/
    The web portal page is a script that gathers the user’s logon credentials and sends back to the FortiGate a POST message of the format https://<FGT_IP>:1000/fgtauth with data magic=session_id&username=<username>&password=<password>. (The magic value was provided in the initial FortiGate request to the web server.) The script used for this example is here.
    I have seen that the initial redirect looks something like:
    https://192.168.1.204/guest/fortigate_cp.php?login&post=http://172.16.2.1:1000/fgtauth&magic=030d0d90d699c5a8&usermac=74:da:38:9f:cb:93&apmac=70:4c:a5:5e:3f:24&apip=172.16.2.1&userip=172.16.2.10&ssid=Captive%20portal&apname=FGT51E3U17001115&bssid=00:00:00:00:00:00&_browser=1
    So the "magic" id is provided by the initial redirect from the fortigate.
    I edited the footer HTML of the captive portal, there you can see that the values are provided as well
    I trying to find a way to send the POST message after the acceptence of the terms.
    So far, I have tried to following:
    Screen Shot 2018-01-14 at 15.58.16.pngScreen Shot 2018-01-14 at 15.58.53.png
    With no succes.
    Does anybody have any iedeas how to populate the POST URL with the right attributes?
  • 2.  RE: Captive portal with Fortigate
    Posted Jan 14, 2018 10:06 PM
    have you taken a look at the following document?
    Integration with 3rd Party Enforcement Points ClearPass & Fortinet utilizing RESTful API and RADIUS Accounting
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=18160
