last person joined: 8 hours ago
captive portal with split-tunneling involving RAP AP's
  • 1.  captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 12:26 PM
    I've got a problem with Captive Portal.  High-level config:  a captive portal with split-tunneling involving RAP AP's.  It drops the user in a VLAN that has src-nat enabled. Inter-vlan routing enabled too.  It's using the out-of-the-box logon-control rule set for the guest-logon user role.  Here's the problem:    I can't seem to get an IP address which is being served out by the controller.
    Another observation is the parameter, ip cp-redirect address has a value different from the vlan where captive portal users are assigned.  Could this be the problem?
  • 2.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 12:56 PM
    Couple of things to confirm.
    1. The VLAN the user is dropped into is defined on the controller
    2. The controller has an IP on that VLAN
    3. DHCP is enabled
    4. The user is put into a role where traffic is "permitted"; the default logon-control and captiveportal should suffi
    To confrim policies for that role, run the following for "Initial Role" of that AAA profile:
    show rights <name of role>
  • 3.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 02:24 PM
    1.  VLAN is configured on controller  (VID 11)
    2.  IP is assigned to this VLAN,  192.168.20.1/24
    3. DHCP is enabled
    4.
    USPHXNRFW101) #show rights CUST_guest-logon_init_role
    Derived Role = 'CUST_guest-logon_init_role'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Periodic reauthentication: Disabled
     ACL Number = 65/0
     Max Sessions = 65535
     Captive Portal profile = Cust_GuestAccess_RAP
    access-list List
    Position  Name           Type     Location
    1         logon-control  session
    2         captiveportal  session
    logon-control
    Priority  Source  Destination  Service   Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6
    1         user    any          udp 68    deny                             Low                                                           4
    2         any     any          svc-icmp  permit                           Low                                                           4
    3         any     any          svc-dns   permit                           Low                                                           4
    4         any     any          svc-dhcp  permit                           Low                                                           4
    5         any     any          svc-natt  permit                           Low                                                           4
    captiveportal
    1         user    controller   svc-https        dst-nat 8081                           Low                                                           4
    2         user    any          svc-http         dst-nat 8080                           Low                                                           4
    3         user    any          svc-https        dst-nat 8081                           Low                                                           4
    4         user    any          svc-http-proxy1  dst-nat 8088                           Low                                                           4
    5         user    any          svc-http-proxy2  dst-nat 8088                           Low                                                           4
    6         user    any          svc-http-proxy3  dst-nat 8088                           Low                                                           4
    other observations that may help...
    I changed to tunnel mode instead of split-tunneling.  I got an IP address in the range specified for the vlan assigned for this captive portal.  I successfully got redirected to the cp splash page, authenticated.  Although I could not browse the Internet, probably need to open more rules, and/or create rules at the upstream firewall, CP is working. I just can't get this DHCP to work.
  • 4.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 02:57 PM
    What the does the firewall show?  <show acl hits>
    Is the VLAN 111 assigned to a port w/ link? Or is "operstate up" enabled on this VLAN? (admin state and protocol state up?)
    Just trying to check everything.
  • 5.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 03:09 PM
    Historically I had hits...see below.  I cleared the counters and initiated a connection and got no hits.
    The original configuration is having this VLAN 11 unbounded to any interface and just have "operstate up." For troubleshooting, I assigned this vlan to a physically connnected interface, removed the operstate up statement and tested again.  Same results.
    CUST_guest-logon_init_role            logon-control                     any   any                      svc-dns           permit                      2244      2244        8686
    CUST_guest-logon_init_role            logon-control                     any   any                      svc-dhcp          permit                      9         9           8687
    CUST_guest-logon_init_role            captiveportal                     user  any                      svc-http          dst-nat        8080         28        28          8690
    CUST_guest-logon_init_role            captiveportal                     user  any                      svc-https         dst-nat        8081         260       260
  • 6.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 04:32 PM
    A couple more:
    show interface vlan 11
    show vlan 11
    show ip interface brief
  • 7.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 04:48 PM
    (USPHXNRFW101) #show  interface vlan 11
    VLAN11 is up line protocol is up
    Hardware is CPU Interface, Interface address is 00:0B:86:6E:93:14 (bia 00:0B:86:6E:93:14)
    Description: 802.1Q VLAN
    Internet address is 192.168.20.1  255.255.255.0
    IPv6 Router Advertisements are disabled
    Routing interface is enable, Forwarding mode is enable
    Directed broadcast is disabled, BCMC Optimization disabled ProxyARP disabled Suppress ARP enable
    Encapsulation 802, loopback not set
    MTU 1500 bytes
    IP NAT Inside is enabled on this interface
    Last clearing of "show interface" counters 6 day 17 hr 44 min 1 sec
    link status last changed 6 day 17 hr 41 min 1 sec
    Proxy Arp is disabled for the Interface
    Auto Operstate up is enabled for this Interface
    Tunnels Configured on this Interface:
    Tunnel 0,Tunnel 0,Tunnel 0
    (USPHXNRFW101) #show vlan 11
    VLAN CONFIGURATION
    VLAN  Description  Ports  AAA Profile
    11    VLAN0011            N/A
    (USPHXNRFW101) #show ip interface br
    Interface                   IP Address / IP Netmask        Admin   Protocol
    vlan 372                   10.20.72.10 / 255.255.255.0     up      up
    vlan 1                      unassigned / unassigned        up      down
    vlan 303                   10.20.32.10 / 255.255.255.0     up      up
    vlan 364                   10.20.64.10 / 255.255.252.0     up      up
    vlan 368                   10.20.68.10 / 255.255.252.0     up      up
    vlan 11                   192.168.20.1 / 255.255.255.0     up      up
    vlan 20                    10.20.20.31 / 255.255.255.0     up      up
    loopback                    unassigned / unassigned        up      up
    mgmt                        unassigned / unassigned        down    down
  • 8.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 05:16 PM
    That all looks good too.
    How about the output of these commands:
    show ip dhcp statistics
    show ip dhcp database
    show ip dhcp bindings
  • 9.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 05:25 PM
    the binding 192.168.20.26 was when I had the VAP in tunneled mode.
    (USPHXNRFW101) #show ip dhcp statistics
    Network Name           192.168.20.0/24
        Free leases        228
        Active leases      1
        Expired leases     0
        Abandoned leases   0
    Network Name           10.20.68.0/22
        Free leases        998
        Active leases      0
        Expired leases     0
        Abandoned leases   0
    (USPHXNRFW101) #show ip dhcp database
    DHCP enabled
    # Global scope option declarations
    # V368-RAP-Clients
    subnet 10.20.68.0 netmask 255.255.252.0 {
        default-lease-time 86415;
        max-lease-time 86415;
        option domain-name "lostarrow.com";
        option vendor-class-identifier  "ArubaAP";
        option vendor-encapsulated-options  "10.20.72.10";
        option domain-name-servers 10.20.11.60, 10.20.11.70;
        option routers 10.20.68.10;
        range 10.20.68.25 10.20.71.254;
        authoritative;
    # GuestPool
    subnet 192.168.20.0 netmask 255.255.255.0 {
        default-lease-time 43200;
        max-lease-time 43200;
        option domain-name-servers 8.8.8.8, 8.8.4.4;
        option routers 192.168.20.1;
        range 192.168.20.26 192.168.20.254;
        authoritative;
    (USPHXNRFW101) #show ip dhcp binding
    lease 10.20.68.25 {
      starts epoch 1379004607; # Thu Sep 12 09:50:07 2013
      ends epoch 1379091022; # Fri Sep 13 09:50:22 2013
      tstp epoch 1379091022; # Fri Sep 13 09:50:22 2013
      cltt epoch 1379004607; # Thu Sep 12 09:50:07 2013
      binding state active;
      next binding state free;
      hardware ethernet 08:11:96:1c:24:a8;
    lease 10.20.68.25 {
      ends epoch 1379005551; # Thu Sep 12 10:05:51 2013
      tstp epoch 1379005551; # Thu Sep 12 10:05:51 2013
      binding state free;
    lease 192.168.20.26 {
      starts epoch 1379005552; # Thu Sep 12 10:05:52 2013
      ends epoch 1379048752; # Thu Sep 12 22:05:52 2013
      cltt epoch 1379005552; # Thu Sep 12 10:05:52 2013
      starts epoch 1379006484; # Thu Sep 12 10:21:24 2013
      ends epoch 1379049684; # Thu Sep 12 22:21:24 2013
      cltt epoch 1379006484; # Thu Sep 12 10:21:24 2013
      starts epoch 1379007661; # Thu Sep 12 10:41:01 2013
      ends epoch 1379050861; # Thu Sep 12 22:41:01 2013
      cltt epoch 1379007661; # Thu Sep 12 10:41:01 2013
      starts epoch 1379007890; # Thu Sep 12 10:44:50 2013
      ends epoch 1379051090; # Thu Sep 12 22:44:50 2013
      cltt epoch 1379007890; # Thu Sep 12 10:44:50 2013
  • 10.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 05:24 PM
    Does the issue happen with all VLANs?  If you change the VAP to use one of your other VLANs, does the client get an IP?
  • 11.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 05:49 PM
    I get the same problem.  I placed the cp vap on a vlan used by 802.1x vap; this vlan is also not bound to an interface.  I know this works as I have no problem with 802.1x vap.
  • 12.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 12, 2013 07:30 PM
    Wow, that looks ok too.
    I'm down to debug logs for DHCP now.
    logging level debugging security process dhcpd
    logging level debugging network subcat dhcp
    <test dhcp w/ client> then...
    show log security all | include <client mac>
    show log network all | include <client mac>
    I'm wondering if the request is getting to the controller at all.
  • 13.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 13, 2013 04:14 AM
    hmmm,
    I only go this....
    Sep 13 00:11:17 :126038: <WARN> |wms| |ids| AP(6c:f3:7f:d1:a5:b0@USLOCXNRAPXXX): Cleared Station Associated to Rogue AP: An AP is no longer detecting a client 08:11:96:1c:24:a8 associated to a rogue access point (BSSID 74:d0:2b:40:bf:2c and SSID newjetty_5g on CHANNEL 149).
    Sep 13 00:12:05 :126037: <WARN> |wms| |ids| AP(6c:f3:7f:d1:a5:b0@USLOCXNRAPXXX): Station Associated to Rogue AP: An AP detected a client 08:11:96:1c:24:a8 associated to a rogue access point (BSSID 74:d0:2b:40:bf:2c and SSID newjetty_5g on CHANNEL 149).
    Sep 13 01:07:21 :126038: <WARN> |wms| |ids| AP(6c:f3:7f:d1:a5:b0@USLOCXNRAPXXX): Cleared Station Associated to Rogue AP: An AP is no longer detecting a client 08:11:96:1c:24:a8 associated to a rogue access point (BSSID 74:d0:2b:40:bf:2c and SSID newjetty_5g on CHANNEL 149).
  • 14.  RE: captive portal with split-tunneling involving RAP AP's
    Posted Sep 13, 2013 09:17 AM
    Doesn't look like the request is getting to the controller at all based upon those log results.  Can you tell us the version of ArubaOS?
    Also run the following for that RAP:
    show ap details ap-name <name-of-AP>
    show ap bss-table ap-name <name-of-AP>
