captive portal with sponsors limit attemps
  • 1.  captive portal with sponsors limit attemps
    Posted Jul 22, 2015 04:36 PM
    I use a captive portal with sponsors. Is there a way to limit the number of attempts that a guest has to register as a guest and send an e -mail to the sponsor? The goal is not to send spam to sponsor.
    Alex
  • 2.  RE: captive portal with sponsors limit attemps
    Posted Jul 22, 2015 07:40 PM
    Download the ClearPass Guest 6.5 user guide here: https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=16526 and search for auto_update_account.
    If you add the auto_update_account field to the create_user form and give it a value of zero, it will not allow the user to create another account with the same username.  It is not perfect, but it could work.
  • 3.  RE: captive portal with sponsors limit attemps
    Posted Apr 06, 2016 09:13 AM
    But if it the username of the guest form is random?
    How the can the clearpass limit the registration to the same sponsor?
    We have this issue on a client, that they need to have self-registration with sponsor, but without the Valid of sponsor, the guest have 2 hours free.
    How we can limit the petitions that the sponsor gets?
    thanks
  • 4.  RE: captive portal with sponsors limit attemps
    Posted May 25, 2016 09:26 AM
    i don't  see a direct solution for that.
    work arounds would be to demand a valid email or mobile number to prevent keep making account. or you just provide two options, one without sponsor for two hours and one with sponsor for longer.
