captive portal with wpa-psk
  • 1.  captive portal with wpa-psk
    Posted Mar 15, 2012 05:53 AM
    Hi all!
    I would like to configure my ssid "guest" with wpa-psk encryption with passphrase, once the guest type the correct word the controller redirect to captive portal.
    I'm trying to configure this, but the controller shows the following message:
    Error processing command 'wlan ssid-profile "ssid-guest" opmode wpa2-psk-aes':Error: dot1x profile needs to be enabled in aaa profile "aaa_guest" to support opmode "wpa2-psk-aes" configured in ssid profile "ssid-guest"
    anybody knows what commands i should type to enable dot1x profile in aaa profile "aaa_guest"?
    maybe the questions is so easy but i'm not sure about the config, so i prefer to ask here before doing something wrong.
    The config of "aaa_guest":
    initial-role "role-guest-logon"
    dot1x-default-role "role-guest-authen"
    thanks in advance!
  • 2.  RE: captive portal with wpa-psk
    Posted Mar 15, 2012 07:15 AM
    @juancarlos.perezromero@telindus.es wrote:
    Hi all!
    thanks in advance!
    try :
    config t
    authentication-dot1x defalt
  • 3.  RE: captive portal with wpa-psk
    Posted Mar 15, 2012 07:53 AM
    thanks it works!
    now clients has to enter the wpa2 key and after they will be redirected to captive portal.
    thanks!
  • 4.  RE: captive portal with wpa-psk
    Posted Mar 15, 2012 08:22 AM
    Glad that we can help!
  • 5.  RE: captive portal with wpa-psk
    Posted May 19, 2013 05:41 AM
    i facing the same issue , but i want to know what the cause of this error ??
  • 6.  RE: captive portal with wpa-psk
    Posted May 19, 2013 06:21 AM
    Use the WLAN/LAN Wizard to create the Captive Portal to Avoid that error.
  • 7.  RE: captive portal with wpa-psk
    Posted May 19, 2013 12:54 PM
    Wpa-psk requires a 802.1x profile in the AAA profile. You see that error when it is not configured. The wizard creates it automatically.
  • 8.  RE: captive portal with wpa-psk
    Posted May 20, 2013 03:39 AM
    i tried to make it by the wizard many time , but nothing happen also the same error when i try to make a new AP group or new SSID
