Captive Potal Issues
  • 1.  Captive Potal Issues
    Posted Aug 05, 2013 01:57 AM
    I have configured Captive Portal in the network but its not letting me browse any web page.
    When i got connected to the CP ssid, it assigns me the correct role i.e. "CP_SSID-guest-logon" (where CP_SSID is the ssid for captive portal) that has the preset policies "logon-control and captive" and also takes me to CP page for authentication. After providing the correct user name and password (whose entry is in Internal DB) it waits for 10 sec before redirecting to the requested webpage, which is normal, but after that it either doesn't show me any webpage (blank white page) or again shows me Captive portal page to enter the username and password which was already provided seconds ago.
    Now can anyone tell me whats going on?
    Interesting thing is that after successful authentication, i can ping any webpage i want but when it comes to browsing the page, aahhh... :(
    Details are;
    MC3200
    AOS is 6.1.3.9
    Firewall Hits
    User Role Hits
    Role Policy Src Dst Service Action Dest/Opcode New Hits Total Hits Index
    CP_SSID-guest-logonlogon-controlanyanysvc-icmppermit 142014208249
    CP_SSID-guest-logonlogon-controlanyanysvc-dnspermit 8358358250
    CP_SSID-guest-logonlogon-controlanyanysvc-dhcppermit 15158251
    CP_SSID-guest-logoncaptiveportalusercontrollersvc-httpsdst-nat80811321328253
    CP_SSID-guest-logoncaptiveportaluseranysvc-httpdst-nat80801361368254
    CP_SSID-guest-logoncaptiveportaluseranysvc-httpsdst-nat80811021028255
    CP_SSID-guest-logon anyany0deny 102910298259
     Please help.
    Thank you.
  • 2.  RE: Captive Potal Issues
    Posted Aug 05, 2013 04:32 AM
    In your Captive Portal Authentication Profile, what is the Default Role?
    What role does the user end up in AFTER authentication?
  • 3.  RE: Captive Potal Issues
    Posted Aug 05, 2013 08:20 AM
    Thanks cjoseph. I got it to work with your kind support.
    I forgot to change the default role which was same as initial role that's why it never got changed :)
    Please clearfy 1 more thing before we mark this thread as "solved".
    Now i want to NAT the guest traffic hide the network IP scheme and resources, can you please help me achieve that?
    I have 3 VLANs on the controller, 1 is default (172.16.0.254), vlan10 is for employee and vlan50 is for uplink (4th port is assigned to vlan50 with client's network parameters and using external DHCP/DNS servers). Clients get the IPs from external server on vlan50 and Captive portal SSID is assigned vlan50, say 192.168.0.x. Now what should i do that the guest users get the IP address like 10.10.10.x. as well as they cannot access/ping the internal FTP or DHCP/DNS servers???
    Please guide.
  • 4.  RE: Captive Potal Issues
    Posted Aug 05, 2013 08:23 AM
    If your users are on VLAN50:
    config t
    interface vlan 50
    ip nat inside
    If you want to block traffic to internal resources, go into the "authenticated" role and add ACLs that block internal traffic.  If your clients are using an internal DNS server, make sure that the ACL to block internal traffic comes after permitting DNS.
  • 5.  RE: Captive Potal Issues
    Posted Aug 07, 2013 02:13 AM
    I am facing the same problem. Will try that.
  • 6.  RE: Captive Potal Issues
    Posted Aug 07, 2013 02:15 AM
    Thanks for guiding me through. :)
  • 7.  RE: Captive Potal Issues
    Posted Aug 05, 2013 07:03 AM
    Check your DNS + gw configuration (under IP>route or under IP>dhcp)
    also - can u printout /screenshot the ACL that authenticated users getting after the captive please.
