Captiveportal GPP not working with IE9
  • 1.  Captiveportal GPP not working with IE9
    Posted Jan 26, 2012 10:01 AM
    Captiveportal using the GPP WebUI is working with Internet Explorer v.8.0.7600.16385 and Mozilla Firefox v.9.0.1 the functions are fine. However, in Internet Explorer v.9.0.8112.16421 – cannot create guest accounts via GPP. IEv9 refreshes every sec making it impossible to create a user, modify, and even logout. Has anyone else had this problem, or similar issue?
  • 2.  RE: Captiveportal GPP not working with IE9
    Posted Jan 26, 2012 10:56 AM
    We can't use IE9 with our captive portal either.
  • 3.  RE: Captiveportal GPP not working with IE9
    Posted Jan 26, 2012 11:05 AM
    Yea, can conform the same issues here - on AOS 6.1.2.7. You should open a support case for it :)
    ..John
  • 4.  RE: Captiveportal GPP not working with IE9
    Posted Oct 03, 2012 10:33 AM
    This is still a problem in 6.1.3.4 ..
