Captove Portal and Multiple Authentication
  • 1.  Captove Portal and Multiple Authentication
    Posted Mar 28, 2013 06:42 PM
    Hi all,
    I have a requirement of doing multifactor authentication when connecting to our Wireless LAN. Basically, the First login  will be Pre-Shared-Key. Once authenticated, the user will be forced to an internal Captive Portal that will authenticate the user to Active Directory. I can login using the PSK and use AD Captive Portal. When I get another user to login in. The PSK works but no more Captive Portal. Any Suggestions would be appreciated.
  • 2.  RE: Captove Portal and Multiple Authentication
    Posted Mar 28, 2013 08:49 PM
    Is this 2nd user on a different device or the same device?   If the same device, there may be a cached entry in the user table for the device still (post AD/Captive Portal).    It is not user specific, but device.
  • 3.  RE: Captove Portal and Multiple Authentication
    Posted Mar 28, 2013 10:25 PM
    The users all have iOS devices. In this case the 2nd user is on a different device.
  • 4.  RE: Captove Portal and Multiple Authentication
    Posted Mar 29, 2013 02:25 AM
    Answering your quetsion do you have clear the box of  Allow only one active user session? on the captive portal authentication profile?
    Just as recommendation,  just putting EAP TLS is more secure than doing those things.  It is not possible to put this kind of authentication?
    Maybe using quickconnect to onboard them all as they are all using IOS devices..  i mean that way you wont have to buy all the clearpass if you don thave money for it.
